Syclone0044
Full Street Trim
- Apr 7, 2002
Hey guys, I've tried getting help on this elsewhere but nobody is as hardcore about alcohol as you guys are, so maybe you can help? My problem is when I get beyond 22 PSI boost or so, with 93 octane and dual nozzle SMC Alcohol (M10 and M15) running 100% methanol, once I get into 3rd gear or so, the turbo will begin to "surge" and the boost will fluctuate and I lose power. I can't figure this out. I wrote about it extensively here if anyone has time to help:
http://www.syty.net/forums/showthread.php?t=40264
Here is an example of what I mean. Look at the pink line. The boost goes crazy.
And so far I have found that it is not the TCC lockup (sometimes it happens in 2nd gear before the TCC locks up), and it doesnt seem to be related to the AFR either. I tried running from stock heat range NGK UR5 @ .028 plugs down to .025 and .022" but no difference.
Thanks in advance,
Thanks in advance,
