Stretch IC Vs. Dutt Neck????
Gnat352
Hey,
I am on the fence about this, my time is in my sig along with my upgrades but was wondering if going to a stretch unit would help me get into the mid-low 11's easier?? Would there be a big improvement from going from a Dutt Neck stocker to a stretched unit?
Im sure a stretched would give you much better results. Giving its much longer and you can grab more air coming in.. I could be wrong but im sure others will chime in.
The Dut neck increases air flow capability over stock by 20%. The stretch probably has the large piping (increased flow over stock), PLUS the additional cooling for the intake charge. That means more boost before detonation. Its a trade-off you'll have to decide for your own goals and pocket book. :)
I'm sure there are people here who could quantify the performance difference and you can look at the expense of each and make your choice. :)
Yup....Im just debating if it's worth dropping $400-$500 for a stretched IC...:) ...If the Dutt Neck can get me low 11's easy then it's not worth it. I am sure I wont feel any " Seat of the Pants" diff if I decide to get one....;)
Yea I would def get a nice used one....Although the 23 row one that Gn1 Performance sells looks real tempting.......:biggrin:
All GNs react differently. Please don't take this one GN to be like all others.
Time slips on a 12 second GN were identical for the Dutt neck & the stocker.
.4 second gain with stretch over stock.
Many mods later the GN was an 11.5 second car.
I got the stuff to take me well into the mid/low 11's but it's KILLIN me to know if the Dutt NEck is holding me back? I think the alky is really helping me out though.....:biggrin:....I would hate to put on a Stretch IC and see little to no results Vs. my Dutt Neck!
Seems funny, a guy with a slower car giving a guy with a faster car advice but our engine set-up is pretty similar. My driveline is stock from the converter back though. My best 60' ft is a crappy 2.10 with 17" street tires. With out alky and on such a soft leave I run 12.90's with a trap of 109 + on 19 lbs. With the alky I run 24 lbs on the street (haven't been to the track yet) and the car is much stronger. Point is, I think you are probably leaving some power on the table with your current combo. Dial up the boost some and I think you'll pick up some mph and the way your car is hooking your et's should drop. With the alky I think you've got more left in your car the way it sits. I don't think your Dutt neck is holding you back yet.
A buddy of mine ran a 11.35 on a TE-44 and ported stock IC, with NO Dutt neck. Pump gas and alchy. I have a ported IC on my car and it works great. For the $200 to do the Dutt neck when its all said and done, thats $200 that could go towards a stretch IC.
Even with a Dutt neck, its still a stock 10-row IC from 20 years ago. Just my opinion on things.
Awesome.....I will just keep my current intercooler and call it a day. Like I said...I think the alky is what makes the Stock intercooler appear big....:cool:
Is it ported? A little time with a die grinder can be worth it! Mine is ported on the inlet and outlet.
When I got the Dutt Neck I ported it a bunch and then had it welded on....so its like 2 3/4 inlet........:biggrin:
