Parts in question:
- CAT stroker crank.
- CAT SFI flexplate
Both parts were ordered from Full Throttle. Both are for internal balance. I called today to talk to tech support directly but was told they were out till Friday and to post my question on thier board. Unfortunately, their "general Buick tech" sections are not frequently visited/updates, so here I am. I need an answer ASAP in order to still have a chance to have a running car for the BPG event Aug 1-3 in Ohio as well as the 2 other races we have planed at E-Town in August…
My post on Full Throttle's Forum:
Need balancer key for crank, plus issue with SFI flexplate fitment... - Full Throttle Speed Tech Support
Issue # 1: I need the balancer key that fits in the snout of your stoker crank.
The slot that was cut from the factory is too wide to hold the OEM Buick size. This crank was purchased from last spring, included in their “stroker kit” – just now going together and in my car. How/where can I get this key?
Issue #2: The SFI flexplate does not sit flush on the end of the crank.
The crank has a rolled fillet (or whatever you want to call it) where the flexplate mounts. Either the flexplate needs to be clearanced or the crank needs to be cut on this spot. What do you recommend I do to resolve this issue?
Thanks.
- CAT SFI flexplate
Thanks.
