Here's my problem:
It started out as an O2 code 44 lean, problem so I swapped in a good Heated used o2 from last year. Then it all went south from there. that did not fix the problem so I put the original back in. then the car starts to stumble and snort from a dead stop with minimal throttle till about 1000 rpm's then fine. Since then these Items where replaced or checked
O2 replaced with Single wire AC delco New
Driver side header crack fixed
Maf sensor changed
reset AIC
Adjusted TPS
Checked and reset cam Sensor
replaced computer
changed chip to Idle at 1100 rpm's
replaced spark plug wires
replaced coil pack
Now the stumble show's up every now and then, car seems slow and heavy from a start. After the car is moving she's good and strong. so I started playing with some of the chips I have.
I put in My stock injector streat chips and car runs perfect but I can not build boost over 12 pounds before getting High knock
I am now lost why would it run fine with the stock injector chips and not the 50# chips. Car ran fine until the 02 lean problem
had no problems with chips before. 50# chips are Jim Testa street and 110 race. Stock chips are Red Armstrong and Thrasher.
could the injectors have gone south, I'm thinking of putting the stock injectors back in.
thanks in advance for the help.
Brad
Maf sensor changed
reset AIC
Adjusted TPS
replaced computer
replaced coil pack
Brad
