Buicksandrail
- May 27, 2001
Hi,
I need some help. Just got the turbo back on. During launch in 1st gear the engine misses and stumbles badly. It is like someone pulled the plug. I have to let off the gas because it sounds like something is wrong. Once I get past 2500 RPM it accelerates like a rocket through all the gears with about 2-3 psi boost. The accelerator pump is working. I adjusted the secondary air vale to open faster but it didn't seem to help. I have not had this QJ carb on this engine before. The engine ran great before the turbo conversion with a 2bbl Holley.
Any suggestions out there?
Thanks as always,
Trent
Thanks as always,
Trent
