Dec 10, 2003 #1 D DorianL Member Joined Jun 7, 2002 Messages 231 I got the pan off - is there any way that I can check if the sump is sucking air ? If it's properly sealed ? MTIA, D.
Dec 15, 2003 #2 7 77 cruiser Well-Known Member Joined May 24, 2001 Messages 1,357 get it checked out yet As long as the filter is tight in the pump & filter tube not cracked you should be OK. I'd think if you were sucking air the readings would be all over the place. Jim
Dec 15, 2003 #3 D DorianL Member Joined Jun 7, 2002 Messages 231 Many thanks 77Cruiser The filter was in there firmly - and I could not detect any crack in it. I did a cold no-TV reading... not so good pressure is high but no real boost on reverse or 1 - 2. But I'm still a quart low, I think. Even with that missing quart, I suspect that the pump has gone south. Pressure test again on Wednesday. I.
