I'm running into an issue where for a reason yet TBD when under boost I hear a pop, decompression and in an instance boost drops to 0. I'm only observing it at boost levels above 15PSI. I'm not seeing any vacuum lines pop off and I'm not seeing any spark retard.
I'm going to take my car again and get some PL data and see if there is any knock, that I'm not seeing on the Scan Master. Also it seems to happen after my I have laid into a few times and at full boost a couple of times.
I have checked all my turbo and IC plumming, all hoses are on securely. Any ideas? I know it is usually a good idea to start with basics. Just wondering if anyone has ran into this issue and what was the cause. Try to narrow down my what it could be.
