Any one use one? How do you keep it from going into OD or N. Shifter Detent Plate This work on the TTA?
Jason
Jason
SignUp Now!I use the Stageright from Ck. Works great so far. Just takes practice shifting. Don't wrap your hand around the shifter, just bump it forward with your palm otherwise when the car launches, it will force you to pull the shifter back into first gear and you'll get a hell of a jerk from reactivating the t-brake.That plate is a great idea. I'll add that to my "to get" list if it works on the tta.
I have a Bat Brake on mine. Its electrically operated. Put it in first gear and press the button.. as soon as you release the button.. car leaves.
Just giving another option.
Razor,
whats is the advantage of an electric one? Can you activate the tbrake in 3rd and let the tranny shift when it wants to?
Jason
If you use and electric Trans-brake yes. I don't think you have to on the stage-right style. If you buy the stage-right style don't jerk it into first while rolling or you will stop rather quickly.
So with the manual one do you just mod the stuff in the tranny and it automatically locks when you pop it into 1st? Or do you have to modify the shifter area too?
Jason
Correct. and no mod to the shifter area.
