T&D roller rockers 1.65 ratio
sixgun86gn
six offender
I need to sell these rockers to buy a set that fits my new TA heads .These rockers are for stock heads and are in real good shape. They have barely been used (around 1000 miles) and have been off the car for about 2 years. I sent them to ArizonaGN to be used on my new motor,not knowing that they would not work. I am sure Nick would have no problem confirming this for me.
I am asking $360 shipped for these,they cost $470 new.I would prefer that payment be through a money order made out and sent to Nick Micale at ArizonaGN. He will ship them directly from there.
Please reply in this post only.
Are there any special requirements to install these on stock heads? I know they're for stock heads but will all the other (head related)stock parts work? Sorry for the dumb questions. :D
The only other requirement that I know of is the use of either taller valve covers or RJC racing valve cover spacers under the stock ones.They come with the bolts and everything you need otherwise.These are so much better than the break prone stock setup.
The rocker ratio is 1.65 as stated in the thread title.
Unless you are asking what the definition of rocker ratio is.
That would mean that for every inch of pushrod movement the valve would move 1.65 inches.For example if you have a cam with .400 lift at the lobe,with a 1.65 rocker valve lift would actually be .660 as compared to .620 from a stock ratio of 1.55.
