Tach not accurate & more!!!!!
cesarp
#1 - My tach is working, and lights up fine, but in park it shows that is idling about 1000 ~ 1500 rpm's faster that it should be. When I'm driving or step on the gas most of the time it red lines but I know that I'm not redlining it is just the factory gauge is not reading right. I would like to get this fixed without having to put an aftermarket one on. Boost seems to be accurate at this point. Any ideas on that?
#2 - my volt gauge is always on. The battery & alternators are working fine but the volt light on the dash is alway on. It is probably a ground or wire but would like to see if you guys can recomend me on where to start.
#3 - My domelight dimmer switch works but when I flip it all the way up to turn my lights inside the fuse blows all the time. I mean all the time, ONLY when I flip it all the way up to turn my interior lights on. Any ideas. Thanks.
