its a beautiful 85 with 87 convertion ----and now will be converted to classic fast --has a astro roof doesnt leak the gn ---- fresh 3.8 30 over --speed pro forge pistons - stock rods w/arp bolts / new turbo crank / billet main caps with arp bolts heads are ported and polished with arp head bolts -intake is ported and polished -- 83# injectors /fast bank to bank computer and new fast wiring engine wiring harness needs to be installed - new billet intake spacer and billter vacuum block -new billet ac delete to mount the twin precision 5557 billet impeller turbos- billet fuel pressure regulator -atr single shot exhaust with borla muflers-art carr 3400 stall with new built 200 trans with overdrive --car is set to run high 9s with full stock interior ---all parts except for parts stated as new have under 400 miles on them ----new walbro 255 intank pump -qa1 12way adjustable qa1 front shock --rear are stock ---hotchkis front and rear sway bars and springs --front end has newer poly bushings --and brand new mickey thompson drag radials --interior and exterior are 8.5 out of 10 --- engine -turbos and fast system has to be installed and doesnt have wheels --
have to install engine -turbos -fast-and fast harness-wheels - fuel pump
im not hurting for cash so please make seriuse offers just looking to start a new project ---thanks Vince --cel 773 491 8806 can text if have quastions and pix can be emails ----thanks
also has lc1 wideband --and im sure i forgot more stuff--- $9300
