Here's the deal:
If I put my car into OD,it stays in drive(3rd) for a long time before it shifts into 4th.
If I get out onto the highway,in OD,it takes about 2 mins,at 60 to 65, before it shifts.
Everything else is fine with it,UNTIL.......I turn the A/C on.
Then all new problems start.
I'll be going at about 30 or so in drive,just touch the gas and it kicks down to first violently,hits 2nd for a split second and goes back to 3rd.
This thing has a mind of its own.
TV cable is adjusted correctly.
Shifter linkage is also correct and VS sensor is working as far as I can tell.
I just got the car about 8 weeks ago and the owner told me he didn't know if it had a shift kit in it.
I can't tell.It seems to shift like a untouched trans.
I did add a trans cooler and the fluid is clean
I have not pulled the pan.
Got any advice for me?
