TE-60 turbo
Not really, but it depends on how much boost you are going to run. Driving around on the street @ 15-17psi should be fine. If you want to run it @ 25psi at the track then, no they are not enough. Upgrade to some 50's or the High Z 57's and never have to worry about them again.
Be safer and quicker with a set of the hi-Z 57s (no ECM mod necessary) with a custom chip from Eric Marshall.
You probably could run it at 23 psi. or so.
Ran my TA62 with Bosch 42.5lb's at 24 psi. boost on pump gas and alky racing.
50's and 57's are a good choice especially if you don't have direct scan available.
i would at least go with 50s . i just git a set and and very happy with them. i switched from 009s , i wasnt having good luck with them.:D
