Oct 4, 2017 #2 Thumper Active Member Joined May 25, 2001 Messages 685 i have a used, known good, turbonetics ball bearing version of the te60, 450 plus shipping. Let me know if interested
Oct 4, 2017 #3 F Forced86 Member Joined Oct 4, 2015 Messages 66 Any shaft play in/out side to side? Is the hole for puck enlarged? 1"?
Oct 4, 2017 #4 Thumper Active Member Joined May 25, 2001 Messages 685 just normal minimum movement, hole enlarged maybe to much, and will come with a new plate so you can make it work for you.
Oct 5, 2017 #5 F Forced86 Member Joined Oct 4, 2015 Messages 66 Ok I will def keep this in mind. Gonna give is a little bit more time to see if I could find a te. Thanks
