te44 sweet spot.
jerrad
how many pounds of boost is the te44 the strongest at? i know someone will say the more the better but ive heard people say that its sweet spot is at this ___ many pounds. thanks jerrad
i made my best dyno hp 440rwhp and best track times 11.80@114 at a rock steady 25.
Depends on your air charge temp. I get 26 psi out of stock turbo and my 49 is set at 25 psi now. There is no particular sweat spot for ones car because of the diffenent combo's. I run alky and it cools the charge like its a 50 degree day out in 80 degree weather. FM, I have no experience at , but im sure it cools the air charge very well also. If you run race gas on a stock set up then I would say around 24psi
HTH
Bo
Mine runs best at 26#. I'd try more boost but I have to pull like this :mad: on the WG arm just to get 26#.
when I had my TE-44 and 50's combo with a stock intercooler...my setup liked 24-25 psi but I ran it as high as 27-28 psi with the alcohol injection (not that I would recommend this boost)...then short after I blew my first and only headgasket:(
TE44
26/27 PNDS WORKED FOR ME WITH STOCK HEADS,AND STRETCH INTERCOOLER COMBO FROM COTTON'S ON MY TE44. LIKED IT SO MUCH REBUILT MY STOCK MOTOR WITH T66 AND KEPT MY 44 FOR A STREET AILY DRIVER...:D
