Test button not working...
DynamicGN
I have an SMC kit, yellow light comes on at 12 pounds, alky is injecting, but when I wanna use the test button at idle, the light doesnt turn on and the car doesnt stumble ( but I hear the solenoid open in the box). It did work for a second after I tapped the box...any ideas?
Check all your connections
I had a problem, it was a bad connection
Ok, I pushed in all the connections, it seems to be working now, hopefully it will stay that way...I had a friend push the test button at idle and I am only seeing 40psi on the alky guage, pump speed is maxed out...Shouldn't the guage be pegged out as well? I'm trying to chase a knock problem, o2's are around 800 all the way through, but am getting alot of knock after 14 psi...as much as 19.5 then I quickly let off, even if I slowly step on it, I still get alot of knock...could it be I am not getting enough alky?
If the pump only goes to 40, then you have a bad guage or pump issue.
Contact Steve at SMC for technical as it pertains to testing his system. He knows best on his product.
HTH
