I recently installed a th-350 in my '86 and found out the other day that I had a crack in my converter and need to replace it. What kind of converter will I need to help me out with my setup. What stall should I use? Should I do a lock up or non-lock? I dont know what kind of converter is in it now because when I bought the trans it was already in there.
My setup:
TE63-1 turbo
202-202 cam
PTE front mount
75lbs injectors
340 fuel pump w/hot wire
If you need anymore information on what else I have that I did not mention let me know. Thanks for you time.
My setup:
TE63-1 turbo
202-202 cam
PTE front mount
75lbs injectors
