TH400 Billet aluminum forward drum
chris718
Turbobitt, I finally finished them. Added the drain holes at the od to help return the oil flowing across those grooved clutch plates to the sump quickly and further reduce clutch housing weight when spinning by keeping the oil from backing up in the drum.Directs are in as well.Will post pics after I install the races.
