th400
motomafia
changing from 200r to th400 what all is needed besides transmission to do this swap / by the way engine and tranny is in 67 nova..... also where is a good spot to get these parts ?
If you have the crossmember that was used for your 2004r, then the 400 will fit right in, with ~ 1/4 extra needed on the mount hole. Other than that, its a pretty easy swap. Note that the only Nova ive worked on was a 72 and it had a th350 so i dont know any other problems that may occur. But in the Buicks, this swap is easy.
