thinking on updating a t-type with a 3.8 s2
Goat
I heart Boost and DRs...
Well I got a gtp block and a spare turbo sitting here and I know I can get the other stuff need for the swap, but stuck at the wiring harness.
86 t-type with the gtp block, but what from that harness could I actually use? Is this possible or is there a kit to buy somewhere?
If I can find this info out I will start this project and have some fun with it since this car didn't have a motor in it when I got it.
I've used the OBDII harness and computer on a LC2, no reason you couldn't get the system working on the engine it was designed for or put the LC2 system on the L67. Would have to swap to the late 80's Century T-type cam sensor connector and get an adapter for the IAC and TPS. Otherwise the sensors swap straight over though wiring lengthening or shortening is probably in the cards.
