Ok, I am about to throw this in my firebird but I want to see what all of you experienced turbo 6 guys think before I go thru with it just because its easier to deal with this stuff while its outside of the car. Also, any guesses on the numbers I might put down on the track or dyno and maybe suggestions on certain parts that should be added? It would be much appreciated.
-3.8 87 GN engine
-stock 87 iron heads ported/polished and thermal coated
-stock intake manifold port matched and thermal coated
-208/208 cam
-diamond forged pistons thermal coated tops
-Engine bored .020 over w/ thermal coating in the combustion chambers
-stock crank
-Everything was balanced and blueprinted
-Accufab 65mm tb / plenum
-egr blocked off
-new ignition
-Lt1 starter
-high volume front timing cover (new timing chain)
-new water pump
-custom fmic
-te45a turbo
-Tial BOV
-custom 3" cat-back w/ electric cutout
-a/c delete
-Pro Built 700r4 w/ 3500 stall, B&M transcooler, transgo shift kit and vette servos w/ poly trans mount.
-Lt1 Maf w/ translator + and extender extreme chip
-Suspension completely redone with Spohn parts (Sfc's,lca's,sway bars, etc..)
-3.8 87 GN engine
-208/208 cam
-stock crank
-egr blocked off
-new ignition
-Lt1 starter
-new water pump
-custom fmic
-te45a turbo
-Tial BOV
-a/c delete
