ChrisCairns
Senior Member
- May 24, 2001
I have a -10 male AN fitting coming out of the bung on the top front of my stage block just behind the water pump. This is the oil return for the turbo. I need to connect this fitting with the turbo but the turbo has the stock type return flange for the stock type return line.
I'm thinking I can just cut off the stock return line a couple of inches below the flange and somehow attach an AN fitting to it so I can connect it to the block's fitting.
Any thought on this or has anyone a better idea?
Thanks.
Thanks.
