SignUp Now!The Car is idling rich on purpose. That is how the Thrashers get their smooth idle. DO NOT run a catalytic converter with a Thrasher chip.Originally posted by tta583
I have the Thrasher for the 868's with 868 injectors. I agree with PaulRV6, runs rich. I have soot in the tail pipes. I really started to notice when I pulled the dump tube and swaped in a CAT.
As stated by someone else, go ahead an lower the fuel pressure. Just do it IN 1LB INCREMENTS! and watch your BLM and O2 numbers. Today's TRs are not all the same.2 things I don't like about the chip. You can not adjust FP as it depends on the 45 psi line off for idle. My guess, the rich problem. Some have run lower FP with no problems. Second is the fast spool. The chip spools like mad but it can cause a boost spike of a few pounds. I noticed mine when I put on a Power Plate. I spike about 23 psi then drop right away to 20. Do a search in the archives and you will find more on it.
Sucks don't it?I have had may car running 20 psi at 0 kr for a long time...
Like I said in the other thread, I gaurantee you will like the Thrasher...even with your 868's.Don't let this stuff bother you if you want to try out the Thrasher. Despite my little issues I really like it. Good idle, it does spool like mad, and cheep!!.
