I have discovered in the California bay area a lot of stations that had 100 octane at the pump are not really 100 octane. I used to run 25 psi all day long but now it seems my car knocks when everything is good. Did some research and found out some of the stations had changed suppliers. Turns out the Motor octane of the local station (trick fuels) 100 is 92+, VP street blaze is 96 and the Sunoco is 95. I can run Sunoco or Streetblaze with no problems but they are around 7.50 per gallon and not close by. I know everybody raves about the Alky systems so I am wanting to look into it further.
How much boost can I run with Alky and super junk California 91 octane?
My current setup is 87 GN with 3.5 inch MAF and extender chip. Precision Front mount Intercooler and there is a Tial Blow Off Valve on the inlet pipe to the throttle body (10" away) and a TE-60 Turbo running 25 psi with a 3" Terry Houston downpipe and Torque Tech dual 3" exhaust with Ultra Flow Mufflers. 2800 stall 9/11 converter with a Built Trans. Racetronix pump, 60lb injectors and injector harness. Motor also has a power plate, adjustable regulator, yada yada. The rest probably doesn't matter... Will I be able to run 25 psi with Alky or will I be pushing my luck and better to keep it at 20? Love to hear some thoughts, thanks!
