To buy or not to buy?
I'd pass unless you actually talk to the mechanic and get his name to see how many of these engines he's assembled in the past.
A 109K total stocker or a rebuild with receipts and good information is all I would trust.
Unless you can find out who did the work and why I'd pass.
Maybe it's 209K? :confused:
You are starting to answer your own question. I'd walk...........................quickly. Drew
*UPDATE*
Ok I made several errors about the car, turns out its a 1986 Buick Regal T-type. Here is the actual car listed on autotrader, with all the work done to it.
Click Here
Hopefully you guys can take a look at it, and tell me what you think once again :) Thanks....
screwed by the friend
Most likely not but it almost has nothing to do with that. Just do all the research you can and that should steer you in the right direction. Drew
