To many goodies which one to use?
2GNS4ME
Hello Autowizard and car audio fans
I just purchased a bunch of stuff from a friend of mine for a good deal..but now i think i have more then i need. The following is what i have..tell me what you guys think i should put in my GN and what kinda a box for my subs
Clarion Head unit believe its 8570z with changer
2 Rockford Fosgate HX2 12" subs (1000W)
2 Hi-Fonic amps(Boltar 1000W and Europa 600W)
1 Fosgate Capicitor 16 VOC
1 optima battery
2 4ohm kicker impulse coaxial speakers...i think they are 6"
1 coustic crossover
2 fosgate midrange
2 mb quartz mids and satellites
1 clarion in dash crossover
I am taking the car in Thurs to get installed at a professional shop and want a good box that they will make for me...what do you suggest. A friend is said not to use cross overs cause the amps have them built in ...thoughts and suggestions would be greatly appreciated.
Thanks.
Joe
1 optima battery
1 coustic crossover
2 fosgate midrange
Install the mids in custom door pods or kick panel pods if you have a component set of either the 5.25 or 6.5.
I would go with a sealed cabinet on the HX2 subs and face them toward the tail lights.
Use the optima battery with a battery isolater and install in rear of trunk with capacitor so you can supply the voltage to the Hi-Fonics amps.
If the amps have internal x-overs then use them or run the amps "flat" and use the external x-overs.
There are different ways to run this set up, this is just "1" of many but I would seriously consider running the second battery to give the amps the juice it needs. Especially the sub amp.
What series are the Boltar and Europa? series VII, VIII, ? Those old HiFonics amps kick ass!!!!
