Torque specs
hiballin
Bettie is the boss
fellas, i need to remove the rear diff cover. does anyone have the torque specs for the allen head bolts and the panhard rod to rearend cover bolts?
thanks!
The torque specs for my Kirban reproduction suspension are
rear end cover 25-30 ft lbs.
lader bar to crossmember 70 ft lbs.
lader bar to rear end cover (upper and lower bolts) 40 ft lbs
panhard and stiffhard bar bolts (bars across the back) 70 ft lbs
Remember to torque on the nut side and not the bolt where applicable
Hope this helps;)
