Track results
V6POWER
Senior Member
I went to the local 1/8 mile track (Piedmont) for test and tune and ran my best mph. The temperature was cool..started out at 59 and ended at 50. Here are my runs:
.692
2.027
5.333
8.018
92.75
.605
1.840
5.161
7.869
91.89
.678
1.872
5.151
7.820
93.44
.656
1.858
5.137
7.804
93.48 (best ever; my previous best in FL was 92.8 on a 43* night)
I was running the 23* Extender with 93+alcohol. Boost was 23-24 with zero knock and I kept decreasing tire pressure (19#-14#). EGTs were low to mid 1500s, except the second run which was 1453. O2s were low 800s. I need to either turn up the boost or lean it out some.
hey jim its rick got some chips from you at grill57 was with gary car is running good i also got a ex tendder chip 98oct still tuning but so far it is doing good.are you doing your on tuing on you translater to. i have the plus do you ? this is for the timing of the car keep that car running good rick
Hi Rick--I have the regular Translator. I have fp set at 43 static and the Translator at 6% rich at WOT. As I noted above, I either need to turn down the fp or increase the boost. I am a little rich at the end of the run.
sounds good i am playing with it and it seems to be working good have not got it perfect yet.its just a lot of tuing with the alky ,translater+ ls1 maf,and the extender.all toghther its alot to make it all work right my fuel is at 45 thanks rick
hey all
you need to come to the rock on nov. 9 and 10. they are having some good classes and it should be fun. Im going to be bring about 5-6 cars with me maybe more
Richie
what kind of classes are you talking about . do you have any information on the dates you are talking about.with the classes.do thay have a class for street tires????? have not run my car at the track need to. so i can get some idea of how fast the car is see ya rick
