trade my clean T for a 10 sec GN
rwrows
will trade up or down for a 10 sec GN. Don't want a cage. do want a/c and heat. don't want t tops. anyone? here's my ad
1987 Buick Regal Turbo T (t-type, grand national)
This car has been meticulously maintained by Jim Dunn ( BuickTurboPerformance.com ). Jim overhauled the engine about 4000 miles ago. The transmission was just freshened up less than 500 miles ago. The car is clean inside and out. Many many new parts. TURN KEY, EVERYTHING WORKS
ENGINE: <br><br>
-3.8 V-6 Turbo<br><br>
-completely rebuilt approx. 4000 miles ago<br><br>
-TRW forged pistons<br><br>
-206/206 Hi performance cam and lifters<br><br>
-TA 49 Turbo<br><br>
-Steel Double Roller Timing Chain<br><br>
-Moly Rings<br><br>
-Forged steel crank<br><br>
-Reconditioned heads w/ 3 angle valve job and LT1 springs<br><br>
-009 42.5 lbs injectors<br><br>
<br><br><br><br>
TRANSMISSION: <br><br>
-fresh overhaul<br><br>
-2800 stall speed Pat’s converter<br><br>
-shift kit<br><br>
-B&M trans super cooler<br><br>
-deep aluminum trans pan<br><br>
-driveshaft loop<br><br>
REAR<br><br>
-3.42 posi rear<br><br>
-aluminum pumpkin cover<br><br>
-airlift air bags<br><br>
<br><br><br><br>
TIRES<br><br>
-brand new Mickey Thompson Drag Radials on rear 255/60R15<br><br>
-BFGoodrich Radial T/A’s on front, approx. 4000 miles on them<br><br>
<br><br>
PERFORMANCE<br><br>
-Quarter mile: 12.844 @ 104.92 (16 lbs. of boost) <br><br>
This car has made only one pass at the track with it's current setup. It will go
low 12s easily and will go high 11s with some race gas and more
boost<br><br><br><br>
MISCELANIOUS<br><br>
-T-Tops<br><br>
-W02 blackout package<br><br>
-K&N big mouth air filter<br><br>
-3” MAF translator<br><br>
-chrome mass air pipe<br><br>
-adjustable wastegate<br><br>
-stainless thermostat housing<br><br>
-160 thermostat<br><br>
-accufab hot-wirted xp fuel pump<br><br>
-3” SS Terry Houston Downpipe with dump<br><br>
-3” high flow catalytic converter (gutted) <br><br>
-bowling green customs 2 ¾ exhaust with flowmaster muffers<br><br>
-driverside header was bin welded<br><br>
-93 octane street chip<br><br>
-car is equipped to run Directscan<br><br>
-Moog front and rear springs<br><br>
-Moog idler arm and control arm kit<br><br>
-Kyb shocks<br><br>
-Rear seat braces<br><br>
-Front fram braces-<br><br>
-Under hood braces<br><br>
-Connecting front brace kit<br><br>
-Auto-meter boost/vac gauge<br><br>
-Scanmaster<br><br>
-145 speedometer upgrade with analog dash<br><br>
-headliner and sun visors have been redone<br><br>
-dual sport mirrors<br><br>
-drivers side remote<br><br>
-console<br><br>
-cruise control<br><br>
-BUMPING COLD A/C<br><br>
-Delay wipers<br><br>
-Tilt wheel<br><br>
-Bucket seats<br><br>
-Drivers side power seat<br><br>
-Power trunk realease<br><br>
-Power windows<br><br>
-Power locks<br><br>
-Full carpet kit in trunk<br><br>
-New power master<br><br>
-Sony am/fm CD stereo w/ remote control<br><br>
-Chrome turbo cover<br><br>
-Chrome plated inlet pipe<br><br>
-Polished aluminum valve covers<br><br>
-Cotton’s performance billet vacuum block<br><br>
-Big oil filter adapter with FRAM PH11 filter<br><br>
-Anodized aluminum glovebox plate<br><br>
-Front and rear aluminum bumper fillers<br><br>
-Aluminum overdrive water pump pulley<br><br>
-Upgraded alternator pulley fan<br><br>
-Custom rear pinion snubber<br><br>
-G-body window rattle elimination kit<br><br>
-Passenger’s side breather bypass kit<br><br>
-Custom made oil fill tube breather<br><br>
-Car uses redline gear oil 75w90 in rear<br><br>
-also has an alarm system and a nice sound system
<br><br>
call 215 620 2352<br><br>
I understand, I flew to Detroit to look at it and drove it home. That was a sweet 8 hr. ride. The best thing about this forum is that most of the the cars for sale. Somebody
knows what you getting. But like I said everything is for sale.
If the car is still available- call me on my cell: Matt 347 680 8642- i have a offer for you.
if u could live without a/c and heat we could talk. or you can put it back in.your pm box is full.
