Installed a B&M tranny gauge. Tranny is billet piece with a 9X11 convertor (true 3000) stall all from Bruce @ PTS. Also have a Maxicool tranny cooler, rated at 26000 for cooling efficiency. Running the cooler directly to the tranny bypassing the radiator. Also using some Dextron 5 with added slip additives. Question I have is what are some typical temps your seeing for those who run the temp gauges? I am seeing 120-130 highway temps and 135-140 city. Does this sound right? The gauge sender unit is tee'd off on the return line coming from the tranny cooler (basically measuring the fluid temps going to the tranny). Wondering if my sending unit is inaccurate?
Mike Banas
87GN
Mike Banas
87GN
