22lbChevelle
- Jan 14, 2005
Hello,
Background: Tranny was rebuilt by the go to guy in the seattle area back in 2006. Since finishing the megasquirt project in August I havent gone WOT because I dont have the alky installed and the tune isnt perfect for high boost. I'd say no more than 75% throttle and 10psi.
I was driving to my grandpa's after work and pulled over to test the launch control feature, I was building roughly 5psi on the spark cut and letting off, not actually launching the car. I did this for about minutes then I drove on down the road. Got about a mile out and the tranny started making a buzzing noise so I drove it home.
SO, here are the symptoms:
I can start the engine, warm it up, and there will be no noise.
The second I put it in gear I get a buzzing sound that is coming from the front of the tranny. Here is a link to a video I took this morning:
transmission fail - YouTube
If I put the tranny in neutral it will stop making noise. If I throw it in reverse the noise comes back right away, and it takes about a full second to get into gear.. If I put it into drive again, the noise changes pitch a little bit and it takes a second to get into gear.
On my drive home after the noise initially started, it didnt seem to make the noise or have any problems on the highway but once I slowed and got into the lower gears it came back.
Also, it may help to know that the converter lockup quit working 2 days before this happened.
So do any tranny gurus know what this might be? From my research it sounds like the pressure reg? Any chance it is the torque converter? Will I harm the engine if I drive it roughly 20 miles to my new apartment with a garage where I can pull the tranny out?
Thanks and let me know what more info I can provide!
