Trans Am headlight assemblies, radio, controls, other interior
Roc87
11 Second V6
I have a few things left from the donor vehicle I used for the El Camino. Not pictured are the radio, steering wheel controls, and targa hatch cover. The radio works fine, didn't try out the cassette player, but it has a cracked display cover. The steering wheel controls worked fine and are in good to great condition. Both are the same as what was used in the TTA. The hatch cover has a broken handle, but other than that it is fine. Looking to get $85 shipped for the Radio & steering wheel controls (I'll get pix up later). $35 shipped for the hatch cover.
The drivers headlight has the 2 wire weatherpack connector on the motor, the passenger headlight has a 3 wire weatherpack connector to the motor, but comes with a 2 wire motor. $80 shipped for both
T-Handle shifter - $15 shipped
New (one has slight shelf scratches) airdams for left&right side, should be the same as the TTA $30 shipped for both
Radio/HVAC surround, 3 mounts good, one broken $10 shipped
Headlight/dashlight dimmer $25 shipped
Cig. Lighter assembly $10 shipped
Center console light/switch/bulb $10 shipped
PW Buttons $25 shipped for both
Lower passenger side dash trim w/ "Performance suspension" Emblem $15 shipped
Power Mirror switch $20 shipped
Gear indicator w/ spring mounts and screws $15 shipped
Underdash insulator panels $30 shipped each
Also have a digital dash cluster, HVAC push button controls, grey carpeted kickpanels, a grey spare tire cover, the lower dash trim for driverside (Small plastic trim that goes below steering column) and two rear gold rims.
Thanks TT/Ameasap!
Here is the radio/steering wheel controls, hatch cover, drivers lower dash trim piece and digital dash.
BTW, the hatch covers handle is OK, it's the tabs that keep it held up to the hatch that are broken
Air dams: Sold
Radio and Steering wheel controls: Sale pending
Other stuff will be put on ebay this weekend if it's still around
Roc87,
Silly question but is the unistalled pass side headlight motor operational ? Second...would you sell it separate from all of the other stuff?
Let me know how to test it, I'm not sure if one wire would be positive and the other negative, and the switches/relays just reverse polarity. If you know how I'll give it a shot, just don't want to fry it:redface:
