trans break install ?
tom j
How hard is it to install one of these? I do everythink on my car but I am no expert the only thing I left up to the pros was the short block assembly. The other issue is I don't know what parts are currently in the trans, I do know it was done by Jimmy's transmission, there currently does not seem to be any problems right now it shifts crisp, it has seen mid 11 second passes so far, does lu or non lu converters make a difference, which tb are recomended buy you guys, my current converter is a precision 3200 lu, or should I leave this up to a trans builder, is it any harder than installing a shift kit?
If you can install a shift kit. You can do a transbrake install. Actually kind of similar in what you will be removing and installing.
Your converter should not make a difference.
Brian
brain, I have installed a few shift kits in some 350's I would assume it wouldn't be much different. do have any for sale or recomendations
Tom,
You will not have a problem. The instructions are easy to follow.
I sent you mail about one.
I do have one for you.
Shoot me a mail and I will send you my address.
hipsibri@cs.com
Thanks, Brian
