Trans converter locked up
bobby690_11
I just converted from a powermaster to a vacuum system and had to take the brake and cruise switch off to replace the brake pedal.After putting it all back together it now locks the converter and wont let go even after 70 miles an hour.Is there an adjustment on brake switch that has to be right on to make it work properly?:confused:
I assume you mean it won't "Lock". Make sure the switches are pushed up against the brake pedal when the pedal is in the full up position. You did connect all the wiring back up?
