Transgo non lockup (removed wrong valve)
tta1401
Well, I removed the wrong side. If you orient the picture on the instructions, I removed the correct side but evidentally I was wrong.:rolleyes: I found this out because I didn't have a retainer and after doing a search on here, I found out it was above the TCC solenoid. Lesson learned... Now, I need to know how the valve goes back into its place. I did lay it out the way I took it out but now I am second guessing myself. I have attached a picture of the pieces I am not sure of. I am hoping one of you guys can help me out. A diagram would be very helpful. BTW, what is that valve?
Search pressure regulator in transmission section. There are several pictures of various pr valve setups.
I can't get sucker back in. The reverse boost sleeve will only go in until it reaches the second ring. Pretty much 3/4 of the way in. Would it be easier to do if I pulled the fron pump?
