transmission help
datquick6
to start of with my cars all stock.
i usually drive around town and it feels normal.
yesterday i drove it out of town.
my problem is that wen i am coming to a stop it kind of bucks a little wen and wen im at the stop it shakes a bit.
wen i start going first gear seems good then 2nd comes and it quickly shifts to 3rd.. almost as if it skipped second.. then it drives normal again... got to my destination and let it rest. drove around town and it felt normal again. on the way back home it started doing the same thing.. bucks a little bit at a stop n skips 2nd gear.. could it be something with high speed..seems as it only does it after i get off from a high way or freeway.
could the tranny be going out?
Sounds like the TCC solenoid is sticking. Unplug the electrical connector on the side of the trans and see if the problem goes away. If it does, change the solenoid.
