Transmissions coolers?
bpman1234
So how big of an external transmission cooler would you need if you're bypassing the radiator cooler 200r4 28 stall?
The bare minimum would be 2 - 30000 gvw coolers. More if the converter is spragless. It is recommended to keep the radiator in the circuit.
I would not bypass the radiator , just add an external cooler . David can fix you up , very good tranny man . I bought one from him and will install this spring .
