NEVER ENOUGH
Tim
- Feb 19, 2008
Ok, Here is what I used (attached image). I sanded several pieces down with 320 to get them smooth and get rid of a few knicks, then followed that up with 400 and blew it off, and that up with 600 and blew it off. After reading the instructions again, I went back and hit everything again with 400 and blew it off because I thought a "600" finish would be better. But then realized, if that is what I was suppose to do, it would say that.
I then hit it with the cleaner and let it dry. And again with the 400 and blew it off. Then with the cleaner again and let it dry. (Because thats what it says to do)
I then hit everything with a tack cloth as mentioned here. Everything turned out great except two blemishes.
As you can see, in the bezels, they look good except the one spot. I know I cleaned there, and sanded, and cleaned, and sanded, etc....
What is going on here? Similar small issue in the top left corner of the opposite.
I don't mind going through this again as I obviously need to, but need to know what happened so I don't have to a 3rd time. Besides the fact I now need to get another can of paint. Everything looked even after sanding and cleaning, It was dry.
