My Gn has a consistent miss at idle and low speeds such as driving in my neighborhood or parking lots. The car burbles, pops, and lurches until it shifts into 2nd gear and then it runs fine. The exhaust smells terrible and I even noticed a twinge of fuel smell in my oil when changing it. The car runs super smooth at highway speeds and has no problem making 21 lbs of boost, the problem only seems to be at idle and low speeds. Below are my scanmaster readings (which all looked normal to me) and the steps I have taken to troubleshoot thus far. I plan on bringing it to the performance shop I have had work done at tomorrow to take a look but I was hoping some of you guys could give me some ideas and possibly save me the 2 hour trip and maybe some $.
Scanmaster readings:
.O2 MV-bounces between 066-800 MV
.AF- 7
.L8 44-48
.Bat 13.9
.INT 126-133
.BL 126 +/- 10
.TPS .40 at Idle
.IAC 36-40 (drops as the car warms up)
.CC @10 cc every 2 seconds
Troubleshooting I completed:
1.Removed/checked PCV valve=operating normally
2.Checked plugs/wires=operating normally
3.Checked for vacuum leaks/replaced vacuum lines with silicone kit=no leaks found
4. leakdown test on all cylynders=no issues found
5.replaced fuel filter at last oil change=no difference in performance
6.had fuel pressure checked while it was at the shop being tuned= no issues noted (car is equipped with 50lb injectors and Walbro 307 fuel pump)
I honestly cant think of any thing else that could cause this issue, hopefully one of you guys with more GN experience can think of something I may have missed.
Thanks in advance,
Joe
.AF- 7
.L8 44-48
.Bat 13.9
.INT 126-133
.BL 126 +/- 10
.TPS .40 at Idle
Thanks in advance,
Joe
