Well, I finished getting my truck back together with a new 360 Mopar Performance short block. It runs great on the stock PCM which is fine for now since I'm breaking it in. The problem occurs when I try to hook the FAST into the system. It lurches and chugs and smells like it's running diesel. The IAC moves in and out radically. It finally dies after multiple attempts to idle. It does this whether the WBO2 is in circuit or not. I have several "ballpark" programs that should be pretty close. Frankly, I'm puzzled.....
'99 Dakota, 360, R/T cam, ported R/T heads w/2.02 intake valves, M-1 manifold, 24 lb injectors, JBA headers, 52mm throttle body, Crane 1.6:1 roller rockers, Gibson cat-back duals, MSD-6A ignition, K&N/Evergreen induction, underdrive pulleys, 5 speed
