TTA #104 for sale:
Cloth/T-top, 108,xxx miles.
109 block bored .030 over, .030 over Diamond Pistons, .010 polished crankshaft, billet center main caps, 212/212 comp roller cam (w/ associated valvetrain parts), Rollmaster Double roller w/out tensioner, new HV front cover, TA–64 turbo, Mini starter, ATR 3in. downpipe w/external wastegate, ATR pitbull exhaust, dump and test pipe, no catalytic converter, RJC powerplate, Alkycontrol PAC, LS-1 MAF w/translator and extender chip, Direct Scan w/laptop and bag, KYB adjustable struts and shocks, Spohn adjustable torque arm with drive shaft loop, Spohn panhard bar, 72lb/hr Siemens injectors (modified ECU driver for large injectors), Walbro (307 or 340 not sure which) fuel pump with hotwire kit, 20% worn Nitto extreme tires(front), two sets of Nitto extreme drag radials on rims, Hotchkis sub-frame connectors, 2004R built by Jimmy’s transmissions in Chicago, Coan 3500 Stall n/l converter, 70mm Kenne Bell throttle body and upper plenum, new fiberglass rear spoiler, T-top sun shades, A/C delete heater box(have all A/C components other than A/C lines). New pads and rotors front and rear, new front brake hoses. New battery. Vehicle will be in the Las Vegas area until 11/21/06, after that it will be garaged in Michigan. Also have stretch intercooler with damage from I/C fan and a GN intercooler.
$10,000
Turbo1080 has first dibs.
(1KWIK6, I hope "Brooks" showed you the pictures already).
If interested just PM or e-mail to kovach89
Thanks,
Dave
$10,000
Thanks,
Dave
