BlackRob91
- May 6, 2005
Engine/ car has 69,000 miles
Balanced and blueprinted bottom end
Stock crank std/std etc
Shot peened stock rods on stock pistons with file fit rings
High volume oil pump
204/214 speedpro cam
ARP head bolts
Ported Heads and intake are port matched, back cut valves, LT1 springs
Stock TB and plenum with RJC power plate
Brand new sensors installed throughout
Motron 60lb Injectors
Accufab Adj Regulator
Double roller timing chain
Exhaust
TE67 Turbo
3in Down pipe and crossover
ATR stainless exhaust system with cutout
Transmission/Drive train
CK Performance Stage 2 kit and has a new forward drum - Needs rebuild
3500 Stall converter
Stock 9 Bolt rear
Stock wheels
good Front tires
stock rear tires needs slicks or MT's
Brakes/Suspension
Cross drilled front rotors
Global west tubular sub frame connectors
Line Lock installed center console
Electronics
Razors Alky Kit
Auto meter boost gauge
Hotwire Walbro 340 pump
Extender Chip 23+psi
LT1 MAF
Translator
Call (570)2691143-if any other info is needed please let me know
ARP head bolts
Exhaust
TE67 Turbo
Stock 9 Bolt rear
Stock wheels
good Front tires
Brakes/Suspension
Electronics
Razors Alky Kit
LT1 MAF
Translator
