sixgun86gn
six offender
- Feb 10, 2002
Hey guys.I have tried my alky kit in the past and found out that mixing 70/30 with water helped.so this time I'm going to try 50/50.My question is where should I start with the tuning?I have blown 2 head gaskets in the past trying to get it right.I have since installed an EGT meter and found an intake leak and fixed it.Installed a powerplate as well.I have an extender chip for alky,timing is 23/21,but I have the translator set on base to 19/17 for 93 octane.Where should I adjust the timing and how much per boost?More timing with more boost or add boost and keep the timing where its at?What turn on point works best for you?Should pump speed be higher or lower with the water added?My combo is in the sig.Please help me figure it out and any pointers on using my scanmaster and EGT to tune will be greatly appreciated.It has never worked quite right for me.
