I'm a newby in the buick world and could use a little help. First my car, I have 86 t-type 48,000 original miles. I installed a scanmaster and have been trying to follow the guidelines as to where the tps, and fuel pressure should be. TPS is saying at .40 and WOT 3.8. I think the TPS should be .42 and at WOT 4.6-4.8. Correct? When I hold the throttle at WOT it only shows 3.8, how do I adjust that?
Also, fuel pressure, I have an 340 walbro fuel pump in it w/o the hotwire kit. Is a hot wire kit really necessary? Fuel pressure is at 42lbs. If I disconnect the vacuum line will that simulate WOT? At WOT what should be fuel pressure be?
I am reading Knock at WOT and thought it might be a fuel issue but I'm not sure. Boost is set at 18lbs which I think might be to high, at the risk of sounding like a dumna-- how should I adjust it? I have seen posts about a good references, is there a book or service manual most people would agree I should be using. Thanks
