Baron Von Buick
Big White Guy
- Jan 30, 2003
I have an N/A and i just changed the valve cover gaskets and since then the car has been idling at 3000 rpm, normally its drops to about 1000 rpm or a little lower but not since i changed the gaskets, i should also add this is the first time the car has been "driven" in a while i usually just start it once in a while. I want to adjust the carb but i dont want to screw anything up so does anyone know how many turns the srcews on the carb get from a complete closed postion or am i even making any sense? im just looking to make the car a daily driver no need to tune it to performance specs (if it makes much of a difference?)
What should i do?
Patrick
What should i do?
Patrick
