I just got my laptop and DS setup and I need some help with the figures now. first off the one run I've logged (laptops battery life is around 5 minutes ) was onlt at half throttle, I've been battling a knock problem ever since I got the motor rebuilt. so boost is only at 7lbs and fuel is i little below 40lbs. heres the numbers.
idle: 1/2 throttle
TPS .46 , 2.74
LV8 48 , 255
MAF 6 , 150
IAC 32 , 102
inj 4.2 , 23.5
battery 13.7 , 13.4
MAT 106 ,84 (would jump to 125 on some frames?)
Spark 26 ,20
Knck Rtd 0 ,1.4 (13counts)
A/F 13.7 ,11.7
O2 volts 844 ,890
Basically I just want to know if any of these #'s are out of the ordinary? and what are good numbers to be at? if you need anymore info let me know. thanks
idle: 1/2 throttle
TPS .46 , 2.74
LV8 48 , 255
MAF 6 , 150
IAC 32 , 102
inj 4.2 , 23.5
battery 13.7 , 13.4
Spark 26 ,20
A/F 13.7 ,11.7
O2 volts 844 ,890
