Turbo 400 with MRVB
Super6
i am gauging interest on my th400 built by Sid Neal along with everything to drop it in your Turbo Regal from the shifter(quarter stick) to the driveshaft(aluminum dynotech)..the trans has very quick releasing trans brake, has an ultra bell, and the deep aluminum pan...PTC torque converter 9.5" and Dusty hit my set up perfect the first time..the 70mm turbo spooled like a stocker...i cut and re-welded the safety neutral switch rod so it worked like the stock trans and AN lines to a b&m trans cooler mounted under the battery that has the fan and comes on and off at 180 degrees i believe...it might have 1k on everything at the most...very little street miles..i love the trans but i miss my overdrive..want to go with a 4l80e now...looking for around 3k for everything..can get pics for interested people..text me at 706 466 six two two 7...thanks Bob
