ALVAROG1983
EVIL GN
- Mar 27, 2007
FROM THE TURBO I HAVE A 90 DEGREE FLARE FITTING GOING TO A 45 DEGREE AN FITTING THEN THE OIL DRAIN LINE ALL THE WAY DOWN TO THE OIL PAN I BELIEVE ITS A (-8) IS THAT TO SMALL ALSO ALL THOS DEGREE FITTINGS ON TOP CAUSE OIL TO BACK UP INTO THE TURBO .I PLAN IN CHANGING THIS TO A STRAGHT SHOT FROM TOP TO BUTTOM WITH A (-10 )AND GET RID OF THE CURVES BOUGHT THE CAR THIS WAY.
BY THE WAY NO OIL COMING OUT NO WHERE DOES IT MEAN ITS OK THE WAY IT IS HOPE I MAKE SENSE KIND HARD TO EXPLAIN FOR NEWBE.
