turbo size ???
boosted84
I have a 1984 regal t-type i was wondering if anyone knows the size of the stock turbo thanks
The stock turbo flows 350 cfm. An upgrade, the TA33 flows 700cfm and will require larger injectors, larger fuel pump and an adj fuel pressure regulator. Good luck- Brad
thanks i knew all of that but i was just wondering if there is a ta33 what would the stock one be called thanks again
