Turbonetics T-72 P-trim
brian
Senior Member
Turbonetics T-72 P-trim with an .85 PTE ex housing. The ex housing is set up for an external wastegate hole at 1 1/2in that is slightly to large for a TH style downpipe. RJC has a thin plate that can be purchase to give you a "new" surface to be able to have a THDP used with this. I believe it is $29. (??) And it goes between the ex housing and downpipe.
The turbo has zero play and does not smoke, just came off the car. It is in excellent condition. Less than 2k miles.
$in inliet, 2 1/2in outlet "T cover". (the big one)
This turbo was posted some time ago with an exhaust housing that would clock but not come off. Since then. It was taken to a shop to remove the housing.
$650 shipped.
Thank you, Brian
I also have a NEW Limit built TE-44 with actuator, and 63 PTE housing.
Brand new unused. $725 shipped.
I have decided to go with a 62-62 DBB turbo instead.
actually, i'll take dibs on the turbo. I have PMed you already, but if you could give me your paypal address, I can shoot some money your way.
Currently I have no camera for pics. The turbo is in very good condition.
It is a 3 bolt GN style 85 PTE exhaust housing. I believe the A?R on the compressor side is .70.
The ex housing was pressed off at a turbo builder. No damage to the housing more than a couple hammer blows.;)
